C0lin
Apr 28, 2020Follower
QOS RBR50 error
I have the orbi RBR50 and want to set up the QOS for gaming but when I go and add a new priority rule it always gives me "400 Bad Request: This server does not support the operation requested by your...
Apr 29, 2020Guru - Experienced User
QoS is automatic on Orbi. You can't make any changes.
C0lin wrote:I have the orbi RBR50 and want to set up the QOS for gaming but when I go and add a new priority rule it always gives me "400 Bad Request: This server does not support the operation requested by your client." Is there any way to fix this issue. Thank You in advanced.
- Jmb3dMay 21, 2020AspirantHere is the link for the qos settings. It's disabled by default and gives server error if you try to turn on.
http://orbi login.net/QOS_main.htm- FURRYe38May 21, 2020Guru - Experienced User
That feature is not supported on Orbi systems. Only the speedtest app is.
- CrimpOnMay 21, 2020Guru - Experienced User
Jmb3d wrote:
Here is the link for the qos settings. It's disabled by default and gives server error if you try to turn on.My experience matches yours. Appears (to me) that at one time user manipulation of QoS was part of the design and somewhere along the way they decided to drop it. Makes one wonder why the remainder of the QOS web pages are still in the package, just with no way to reach them. I count at least 14 htm's (not counting the SpeedTest and Speed Test Results).
I also have no idea how one would verify that Orbi "doesn anything" about QoS. I read about some 802.3 standard that ethernet switches say they honor. Would there be evidence in a packet capture that some traffic is "different" than others?
- fury88Oct 13, 2020StarThis would be really nice if they enhanced the current dynamic QoS or gave us options to
Modify. I have the $1000 850 and I’d expect small business performance out of this. With everyone working from home, having router thinks it knows better by prioritizing my son’s XBox over a video conference or file sharing isn’t a good idea during the day 😝
