rhill1959
Aug 21, 2020Aspirant
QoS Setup Orbi RBR850
I just got the Orbi RBR850. So far I like it. My question is about the QoS Setup. I read in an older post for a different Orbi model that you can't adjust the settings. https://community.netgear....
- Aug 21, 2020
rhill1959 wrote:Thanks for the reply. I haven't found a switch within the Orbi panels. Do you know where to look? Seems like it's an always on feature.
Are you using the app or orbilogon.com?
Under orbilogon.com / Advanced / Advanced Setup / Wireless Setup / Check or uncheck "Enable WMM (Wi-Fi multimedia) settings"
rhill1959
Mstrbig
Aug 21, 2020Master
