Chuck_M's avatar
Chuck_M
Mentor
Feb 09, 2019
QOS URL on Orbi
Was fooling around on Orbi and found this:
http://192.168.1.1/QOS_rule.htm
Do you think those QOS rule sets are really functional/implemented or do you think they are orphaned code from previous versions?
    This page does not work, if you make any changes and click Apply you will get an error.
    Looking into the parameters and the file structure in Orbi software you can see that QoS is prepared for in Orbi and can be enabled and disabled. So I hope that Netgear is working on it and it will be coming soon.
    qos_list1=IP_Phone 0 IP_Phone 0 TCP 6670 6670 ---- ----
    qos_list2=IP_Phone 0 IP_Phone 0 UDP 6670 6670 ---- ----
    qos_list3=Skype 0 Skype 0 TCP 80,443 80,443 ---- ----
    qos_list4=0
    qos_list5=Netgear_EVA 0 Netgear_EVA 0 UDP 49152 49155 ---- ----
    qos_list6=0
    qos_list7=Vonage_IP_Phone 0 Vonage_IP_Phone 0 UDP 53,69,5060 53,69,5061 ---- ----
    qos_list8=0
    qos_list9=Google_Talk 0 Google_Talk 0 TCP 443 443 ---- ----
    qos_list10=0
    qos_list11=MSN_messenger 0 MSN_messenger 1 TCP 1863,1503,6891,6901 1863,1503,6900,6901 ---- ----
    qos_list12=MSN_messenger 0 MSN_messenger 1 UDP 1503,2001,6801,6901 1503,2120,6801,6901 ---- ----
    qos_list13=Yahoo_messenger 0 Yahoo_messenger 1 TCP 5050,5000,5100 5050,5010,5100 ---- ----
    qos_list14=Yahoo_messenger 0 Yahoo_messenger 1 UDP 5000,5100 5010,5100 ---- ----
    qos_list15=Netmeeting 0 Netmeeting 1 TCP 389,522,1503,1720,1731 389,522,1503,1720,1731 ---- ----
    qos_list16=0
    qos_list17=AIM 0 AIM 1 TCP 5190 5190 ---- ----
    qos_list18=AIM 0 AIM 1 UDP 5190 5190 ---- ----
    qos_list19=SlingStream 0 SlingStream 1 UDP 554 554 ---- ----
    qos_list20=0
    qos_list21=SSH 0 SSH 1 TCP 22 22 ---- ----
    qos_list22=0
    qos_list23=Telnet 0 Telnet 1 TCP 23 23 ---- ----
    qos_list24=0
    qos_list25=VPN 0 VPN 1 UDP 1701 1701 ---- ----
    qos_list26=0
    qos_list27=On_line_Game 0 On_line_Game 1 TCP 0 0 ---- ----
    qos_list28=On_line_Game 0 On_line_Game 1 UDP 0 0 ---- ----
    qos_list29=FTP 0 FTP 2 TCP 20,21 20,21 ---- ----
    qos_list30=0
    qos_list31=SMTP 0 SMTP 2 TCP 25 25 ---- ----
    qos_list32=0
    qos_list33=PPlive 0 PPlive 2 UDP 7100,7101,8000 7100,7101,8000 ---- ----
    qos_list34=0
    qos_list35=WWW 0 WWW 2 TCP 80 80 ---- ----
    qos_list36=0
    qos_list37=DNS 0 DNS 2 UDP 53 53 ---- ----
    qos_list38=0
    qos_list39=ICMP 0 ICMP 2 TCP 0 0 ---- ----
    qos_list40=ICMP 0 ICMP 2 UDP 0 0 ---- ----
    qos_list41=eMule 0 eMule 3 TCP 4242 4242 ---- ----
    qos_list42=0
    qos_list43=Kazaa 0 Kazaa 3 TCP 1214 1214 ---- ----
    qos_list44=0
    qos_list45=Gnutella 0 Gnutella 3 TCP 80,6346,6347 80,6346,6347 ---- ----
    qos_list46=Gnutella 0 Gnutella 3 UDP 3646,6347 3646,6347 ---- ----
    qos_list47=bt_azureus 0 bt_azureus 3 TCP 6881 6881 ---- ----
    qos_list48=0
    qos_list49=Counter-Strike 1 Counter-Strike 1 UDP 27015 27019 ---- ----
    qos_list50=0
    qos_list51=Age-of-Empires 1 Age-of-Empires 1 TCP 23978 23978 ---- ----
    qos_list52=Age-of-Empires 1 Age-of-Empires 1 UDP 23978 23978 ---- ----
    qos_list53=Everquest 1 Everquest 1 TCP 7000 7000 ---- ----
    qos_list54=0
    qos_list55=Quake-2 1 Quake-2 1 TCP 27960 27960 ---- ----
    qos_list56=Quake-2 1 Quake-2 1 UDP 27960 27960 ---- ----
    qos_list57=Quake-3 1 Quake-3 1 TCP 27960 27960 ---- ----
    qos_list58=Quake-3 1 Quake-3 1 UDP 27960 27960 ---- ----
    qos_list59=Unreal-Tourment 1 Unreal-Tourment 1 TCP 7777,27960 7783,27960 ---- ----
    qos_list60=Unreal-Tourment 1 Unreal-Tourment 1 UDP 7777,27960 7783,27960 ---- ----
    qos_list61=Warcraft 1 Warcraft 1 TCP 6112 6112 ---- ----
    qos_list62=0
  • FURRYe38's avatar
    The UI NG uses is a global router model template. Most of the UI features are embeded in the UI and then depending upon model of product, various features are hidden depending upon model product feature support. This has been known for a while that the QoS url is there. Others have mentioned this as well. I presume the actual QoS code for it is not in the FW and since QoS on Orbi is tied to speedtest.net app and other means of QoS code, code seen on other router models is probably no included in the Orbi FW.
    qos_list4=0
    qos_list6=0
    qos_list8=0
    qos_list10=0
    qos_list16=0
    qos_list20=0
    qos_list22=0
    qos_list24=0
    qos_list26=0
    qos_list30=0
    qos_list32=0
    qos_list34=0
    qos_list36=0
    qos_list38=0
    qos_list42=0
    qos_list44=0
    qos_list48=0
    qos_list50=0
    qos_list54=0
    qos_list62=0
