kick60
Oct 30, 2018Tutor
Quel Satellite additionnel pour RBK40 ...
Bonjour,
Je possède un kit RBK40-100PES, qui est composé du routeur RBR40 et d'un sattelite RBS40.
Je souhaite etendre mon réseau, suis-je "Obligé" de mettre un autre sattelite RBS40-100PES,
Ou...
kick60
Oct 30, 2018Tutor
Hello,
I own a kit RBK40-100PES, which is composed of the router RBR40 and a sattelite RBS40.
I want to extend my network, am I "obliged" to put another sattelite RBS40-100PES,
Where can I put an additional sattelite RBS20-100PS? Is it 100% compatible with the RBR40 router?
I can not find this info anywhere
Thank you in advance for your help to all
Cristofe
Oct 30, 2018Guru - Experienced User
I believe you can use a RBS20 with the RBR40.
30 feet is recommended in between base router and satellite to begin with depending upon building materials.
I recommend contacting NG support in your region to confirm that the RBS will work for you.
