scurvy_mrjones
Jan 30, 2021Aspirant
Query device list from Orbi router (python script)
I published in github a python script that pulls the connected device list from the router. Should work for any device using router firmware version V2.5.2.4. I tested on a RBR50. There are two v...
CrimpOn
Feb 05, 2021Guru - Experienced User
scurvy_mrjones wrote:I published in github a python script that pulls the connected device list from the router. Should work for any device using router firmware version V2.5.2.4. I tested on a RBR50.
https://github.com/scurvylogs/orbi_devices
Thanks for an enjoyable Friday. Works on RBR50, firmware 2.7.2.104 (Almost. Puzzled that uprate and downrate are zero, but the script is simply telling json to "print what you got". ) Also puzzled that it is 'hit or miss' as far as "will it execute this time, or will it fail?"
I probably would have hard coded all of the parameters, rather than two out of three. (IP - hard coded, "admin" - input from file, password - input from file.)
- scurvy_mrjonesFeb 06, 2021Aspirant
I am puzzled too. The ORBI sometimes gives a 401 error. Not sure why. I modifyed the script to retry, but still testing.
Yeah, I just needed the JSON to post to Splunk, a SIEM. I did not create the logic to parse the fields as I do that in the SIEM.
