xiiaobai92's avatar
xiiaobai92
Query on speed difference using OOKLA
Hi, I had recently did a speed test using the OOKLA speed test on my android phone and found that there are quite a big difference between the speed using the OOKLA speed test app and the built-in O...
  • DarrenM's avatar
    May 01, 2018
    You will see differences when using a wireless device to test it.
    DarrenM
