brandoncampbell
Mar 03, 2021Star
Question about AX4200 CBK752 can base by directly connected to satellite.
I was considering getting the AX4200 CBK752. I had a question about if I could link the two devices (base and satellite) together via cat5 so that I would have a more reliable connection between the ...
Mar 03, 2021Guru - Experienced User
yes, you can use a wired backhaul with them.
What is Ethernet backhaul and how do I set it up on my Orbi WiFi System? | Answer | NETGEAR Support
