Vespasion
Apr 04, 2020Tutor
Question about distance and RBK 50
I have the latest firmware for the orbi and using Widows 10 Home. I love my Orbi. It has done what they claim it does. It solved all my wifi extender problems. This is my situation and I am hopi...
Apr 04, 2020Guru - Experienced User
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
- VespasionApr 05, 2020Tutor
Everything you said to do was pretty much already done when I got into the property boxes to change them.
I changed my DNS server to comodo and pages render instantly on my hard wired PC. I have never seen speed like that
before in my tech backward state of La. In order to get more distance I need to go to 2 G speed instead of 5G and see how that works.
