Vespasion
Apr 04, 2020Tutor
Question about distance and RBK 50
I have the latest firmware for the orbi and using Widows 10 Home. I love my Orbi. It has done what they claim it does. It solved all my wifi extender problems. This is my situation and I am hopi...
tomschmidt
Apr 04, 2020Virtuoso
For that long of a distance, I suggest 3 options:
- Add another satellite in between to be able to daisy chain to the further satellite
- Run a CAT6 cable between the router and satellite to give a gigabit link between the two
- Use a WiFi outdoor bridge between the two buildings if they are over 50 feet apart (search Amazon or other retailers)
