Vespasion
Apr 04, 2020Tutor
Question about distance and RBK 50
I have the latest firmware for the orbi and using Widows 10 Home. I love my Orbi. It has done what they claim it does. It solved all my wifi extender problems. This is my situation and I am hopi...
tomschmidt
Apr 04, 2020Virtuoso
For that long of a distance, I suggest 3 options:
- Add another satellite in between to be able to daisy chain to the further satellite
- Run a CAT6 cable between the router and satellite to give a gigabit link between the two
- Use a WiFi outdoor bridge between the two buildings if they are over 50 feet apart (search Amazon or other retailers)
Vespasion
Apr 04, 2020Tutor
Thank you for the fast reply. I have an outdoor air bridge in my cart on Amazon ready to go. I am sure this will boost things up.
Thank you again for your help
- tomschmidtApr 04, 2020Virtuoso
I hope the WiFi bridge works for your issue. Please mark this thread as resolved if that works.
- VespasionApr 05, 2020Tutor
I am sure it will, but that is another almost $300 for the kit I have to come up with.
It is like one problem solved leads to another chunk of money.
Not a critisim of your advise, but that is just life today.
I was wondering, On Amazon they offer a bridge kit that comes with two bridge units for $240. Do I really need two?
They also offer a single bridge as well for much less. Why couldnt I just buy one and place it between my router in one home and the orbi sat. across they yard in the main home? If it would send a stronger signal hop across the yard, wouldnt that be enough instead of buy two bridges?
Thanks
- tomschmidtApr 05, 2020Virtuoso
I have not used a WiFi bridge, but reading about them tells me that 2 are needed to span a longer distance. Both units transmit and receive in a focused signal to each other, thus they can concentrate their power in a straight line rather than in a sphere like a normal antennae. Depending on your distance, it may be cheaper to bury a CAT6 or CAT7 cable between the two buildings to link your router in one building and satellite in another building.
- VespasionApr 18, 2020Tutor
I tried all day to install the bridge and finally gave up. It is way too complicated to install. Every other step requires a password and change of IPS. Too much of a hassle to intall.
I am sending it back to Amazon and getting another orbi satalite instead. Installing Orbi's are a breeze, and they up and running right away.
No hassles, no errors, and no problems.
