Vespasion
Apr 04, 2020Tutor
Question about distance and RBK 50
I have the latest firmware for the orbi and using Widows 10 Home. I love my Orbi. It has done what they claim it does. It solved all my wifi extender problems. This is my situation and I am hopi...
tomschmidt
Apr 04, 2020Virtuoso
For that long of a distance, I suggest 3 options:
- Add another satellite in between to be able to daisy chain to the further satellite
- Run a CAT6 cable between the router and satellite to give a gigabit link between the two
- Use a WiFi outdoor bridge between the two buildings if they are over 50 feet apart (search Amazon or other retailers)
Vespasion
Apr 14, 2020Tutor
I got my Bridge in from Netgear (Amazon) and will attempt to install it today. It looks really complicated and I doubt I have the brains for it, but if i get it up and running and it does its job, I will post resolved on your reply to my original question.
This is why I havent posted resolved yet, because I havent installed the bridge yet.
Thanks
Thomas
