WFHMomma
Jul 15, 2020Follower
Question about memory difference between RBS50 or RBS50Y
I am looking for another satellite to use as an extender for coverage in my backyard. Since I have a screened in porch and weather isn’t a factor, I am undecided between the outdoor RBS50Y and another...
Jul 15, 2020Guru - Experienced User
Mostly nemory is used for FW operations and logging when logging is enabled. Memory will not be the same between the RBR and RBS.
The RBSY should work well if configured and placed in a good distance from the RBR. 30 feet or more is recommended.
Daisy Chain may used or disabled. I would disable Daisy Chain first.
