jgille8
Jul 01, 2017Aspirant
Question about setting up Satellite to switch
So I just bought the AC2200 with the router and 2 satellites. My home is wired for cat6 all over and I have a switch off the router. I'm wondering if at one of the spots I put a satellite if I can ...
Retired_Member
Jul 01, 2017Orbi does not support ethernet backhaul.
jgille8
Does any of the systems like Orbi do that? I wasnt sure on the correct terminology so thanks for that.
- Retired_MemberJul 02, 2017
Orbi is the only system right now like Orbi. Others use Mesh topology.
