Moonras
Jun 17, 2022Aspirant
Question about switching from pppoe to ap mode?
Hello, I was just wondering if anyone has tried switching from Pppoe to ap mode without any issues? I'm using the RBR50 system. Whenever something happens and my internet goes out I have to reset t...
- Jun 17, 2022
Switching to AP mode the RBS will follow. They will just get a IP address from the ISP router thru the RBR thats in AP mode.
While in AP mode the Orbi just acts as a wifi accessible system that passes all traffic to and from the ISP modem is all. Does not routing or device management.
Moonras
Hello, thank you for the quick reply.
I would set the modem/router combo back into it's default mode instead of the bridged mode I have it in now. So the Orbi RBR50 would have a router behind it. My main question is would I have to reconfigure all the satellites with the Orbi RBR50 by simply switching the system to AP mode? Or would everything just continue to work as is just in AP mode with the modem/router doing the routing?
It isn't a huge deal it's just that in AP mode I don't think I'd have to reboot the entire system every time something goes wrong with my ISP or modem. I think because it's PPPOE is part of the problem with having to do that. So if I just let the modem handle the router/PPPOE stuff I think that might help. I just don't really know how the Orbi works in AP mode to be honest, I haven't had the system long and apart from this one issue I absolutely love it. There is a new company around here running fiber internet through the rural areas. I'm hoping it will make it's way here soon but until then I'm stuck with Windstream and it has it's own problems.
Thanks again.
Jun 17, 2022Guru - Experienced User
- MoonrasJun 17, 2022Aspirant
Ok, thank you very much, I will give it a shot then and see if it helps fix my issue or at least not make it so bad having to restart everything. I really do appreciate the help.
