a2fontaines
Apr 26, 2020Tutor
Question for optimal setup (NAS positioning : router or satellite ?)
hello, I have ORBI RBK50 Solution Unique Wifi Multi-Room AC6000. I have a internet box which doesn't work in "bridge mode" so I put the Orbi in "bridge mode". I have : - the Orbi router and the...
a2fontaines
Apr 26, 2020Tutor
sorry eljarviso I did not get the "out" word.
And there is no option to put an ethernet between the Orbi router and orbi satellite... otherwise, i would have bought only a switch and not an Orbi system ;)
For FURRYe38 , i do not have a GB Lan switch...
So the question is quite simple -> should I put the NAS on the ethernet port of the Orbi Router or on the ethernet port of the Orbi satellite ? ;) (i recall that the TV that will be playing content from the NAS is connected with ethernet on the satellite)
Apr 26, 2020Guru - Experienced User
Gb LAN switches are inexpensive.
Try the NAS connected to the RBR first then test the configuration.
