Josser's avatar
Josser
Tutor
Dec 06, 2019
Question on RBR50 WiFi
I just hooked my RBR53 system up with the 2 Satellites. Is there a reason why the 2.4 is stronger the the 5g?  It is on all my devices. I would have thought the 5 would be higher, Thanks for your rep...
  • Josser's avatar
    Josser
    Dec 06, 2019
    Problem solved!. When I had my old routher 2.4 and 5g both came up as networks. Now with Netgear only 1 name comes up and it routes the device to the stronger connection. I did not know this. Must have been hooked up to an old 5g that wasn't working well this morning.. Thanks for all the help, Jerry
