Josser
Dec 06, 2019Tutor
Question on RBR50 WiFi
I just hooked my RBR53 system up with the 2 Satellites. Is there a reason why the 2.4 is stronger the the 5g? It is on all my devices. I would have thought the 5 would be higher, Thanks for your rep...
- Dec 06, 2019
Problem solved!. When I had my old routher 2.4 and 5g both came up as networks. Now with Netgear only 1 name comes up and it routes the device to the stronger connection. I did not know this. Must have been hooked up to an old 5g that wasn't working well this morning.. Thanks for all the help, Jerry
Josser
Dec 06, 2019Tutor
I think I am just going to contact Netgear support on this one to see what they say.
Josser
Dec 06, 2019Tutor
- FURRYe38Dec 06, 2019Guru - Experienced User
Yes, Orbi uses a signal SSID name for both 2.4Ghz and 5Ghz radios. It will help dual band devices get connected to either frequency, however it's up to the connecting device to pick which frequency.
Enjoy. :smileywink:
