superben79
Jun 18, 2017Apprentice
question on reboot
hi,
when i choose to reboot the orbi from the web interface, does it just reboot the base or does it reboot both the base and the satellite? i want to reboot both
1 Reply
hi
not 100% sure on the answer to this as it seems to just reboor the router and that forces the ap's to resync
the easiest way to reboot both is to power cycle each from the switch on the back
there usually isnt a need to reboot the ap's as they are just following what the router is telling them to do
pete
