jdpg2
Sep 13, 2017Apprentice
Question regarding "fast roaming" in the version 2.0 firmware
I would appreciate if someone internal to Netgear would comment on the Fast Roaming option in the recent firmware release. What does this offer that the default "off" mode doesnt? What are the...
peteytesting
Sep 13, 2017Hero
i believe its a variation on 11R in that it does and has something to do with BSS Transition.
however Fast Roaming does not require client support, allowing backwards compatibility with all clients.
spinkick
So, why wouldnt you always have fast roaming on? Is there a speed penalty as mentioned above?
- jdpg2Sep 13, 2017ApprenticeI have posed the question to my level 2 support rep. If he replies I will post it here, but I would prefer a Netgear rep reply to this post. Any thing outher than that is and guestimation at best.
- peteytestingSep 14, 2017Hero
to assist the non 11R clients to move between nodes better and faster , otherwise they can be quite sticky
no as the fast roam aka roaming assistant is only during disvconnect / reconnect , so would have no issue with throughput
- fruman44Nov 10, 2017Aspirant
Any updates here? If there are no tradeoffs, then why does this setting default to "Off"?
- Hydro130Nov 10, 2017Luminary
In my experience, FR caused by phone to bounce back-&-forth between the router and sat way too much. But since the area of my house where I'm most commonly on my phone has some coverage overlap btween my router & sat, that made fine sense to me.
So I keep FR "off" - that way, my phone is stickier to either the router or sat, and that works much better for me.
I imagine FR would work quite well in some other environments, but not mine.
There are never "no trade-offs".
