nepalisherpa
Apr 04, 2020Aspirant
Question regarding Voxel firmware
Hey everyone! Quick question regarding Voxel firmware. I have a RBK53 system (bought from Costco). I'm thinking about installing Voxel firmware only if it prevents Netgear from forcing an update. ...
Retired_Member
Apr 04, 2020
nepalisherpa wrote:Hey everyone! Quick question regarding Voxel firmware. I have a RBK53 system (bought from Costco). I'm thinking about installing Voxel firmware only if it prevents Netgear from forcing an update. Could you guys confirm if installing Voxel firmware will disable auto-updating from Netgear?
Also, if you are using Voxel firmware, how stable is it?
Thank you in advance. :)
If this were to be true where Voxel firmware stops NG from forcing (?) FW on users....what does that do?
How will you update yopur system?
from the readme doc....
Introduction.
This custom firmwares is based on official stock firmware versions for NETGEAR Nighthawk X4 R7500 v1 router, Nighthawk X4S R7800 router and Nighthawk X10 router. The goal of modification is to extend the functionality of these routers and to use full power of CPU and FPU of IPQ806x and AL-514 processors, limited in official firmware.
I wouldn't touch this with a ten foot pole....talk about social distancing....
- nepalisherpaApr 04, 2020Aspirant
The goal is to manually update when I know that the released firmware is stable.
- Retired_MemberApr 05, 2020
And how would you do that? Come in here read the posts? Why not just stop doing manual updates altogether and let NG push the ones you absolutely need?
- nepalisherpaApr 05, 2020Aspirant
Yes! If there is a major issue then I might start seeing posts about it. Plus, I don't want my router auto-updating when, say, I am on vacation. What if the firmware was buggy and, all of a sudden, my security cameras stop working?
I can go on and on about why I want it. The reason for my post is for feedbacks from folks who have used it.
