Kaiyuanben
Jul 07, 2019Aspirant
Questions before buying rbk50
Hi, I am looking to buy orbi rbk50, and I have both Nest hello doorbell and nest thermostat. I did a bit research online seems that orbi is not compatible with nest products or you will have to trun...
Kaiyuanben
Jul 08, 2019Aspirant
Thanks for your reply. Yes. I did read some of them. After reading them, seems there is no definite solution to fix the compatibility issue. You will need to try it out, either to turn off beamforming/Mu-mimo or assign static IP, it is all case specific. That is why I want ask first before I make the purchase.
gr8sho
Jul 08, 2019Virtuoso
Many places will give a two week grace period. I'm actually curious myself about the question. I will not turn off those two features under any circumstances.
