Kaiyuanben
Jul 07, 2019Aspirant
Questions before buying rbk50
Hi, I am looking to buy orbi rbk50, and I have both Nest hello doorbell and nest thermostat. I did a bit research online seems that orbi is not compatible with nest products or you will have to trun...
Jul 08, 2019Guru - Experienced User
NEST Thermostats are compatible with Orbi. My two work well with RBK50 and CBK40 systems. I don't have any NEST Cameras.
Kaiyuanben wrote:Hi,
I am looking to buy orbi rbk50, and I have both Nest hello doorbell and nest thermostat. I did a bit research online seems that orbi is not compatible with nest products or you will have to trun off the beamforming/mu-mimo to get nest to work. Is it ture?
Thank.
- KaiyuanbenJul 08, 2019AspirantThanks.
I think the issue is with nest doorbell now. Seems thermostat is working fine with orbi.- FURRYe38Jul 08, 2019Guru - Experienced User
Might do a search on doorbell. There are a few threads regarding this.
- KaiyuanbenJul 08, 2019AspirantYeah. Seems like I need to disable certain orbi functionality to get the doorbell work but no definite answer yet. It is case specific.
