Kaiyuanben
Jul 08, 2019Aspirant
Questions before buying rbk50
Hi, I am looking to buy orbi rbk50, and I have both Nest hello doorbell and nest thermostat. I did a bit research online seems that orbi is not compatible with nest products or you will have to trun...
Jul 08, 2019Guru - Experienced User
NEST Thermostats are compatible with Orbi. My two work well with RBK50 and CBK40 systems. I don't have any NEST Cameras.
Kaiyuanben wrote:Hi,
I am looking to buy orbi rbk50, and I have both Nest hello doorbell and nest thermostat. I did a bit research online seems that orbi is not compatible with nest products or you will have to trun off the beamforming/mu-mimo to get nest to work. Is it ture?
Thank.
Kaiyuanben
Thanks.
I think the issue is with nest doorbell now. Seems thermostat is working fine with orbi.
- FURRYe38Jul 08, 2019Guru - Experienced User
Might do a search on doorbell. There are a few threads regarding this.
- KaiyuanbenJul 08, 2019AspirantYeah. Seems like I need to disable certain orbi functionality to get the doorbell work but no definite answer yet. It is case specific.
You can temporarily disable the 5Ghz SSID broadcast to see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Check out those other door bell threads. Hopefully you will find something that helps.
