Kaiyuanben
Jul 07, 2019Aspirant
Questions before buying rbk50
Hi, I am looking to buy orbi rbk50, and I have both Nest hello doorbell and nest thermostat. I did a bit research online seems that orbi is not compatible with nest products or you will have to trun...
Kaiyuanben
Jul 08, 2019Aspirant
Thanks.
I think the issue is with nest doorbell now. Seems thermostat is working fine with orbi.
Jul 08, 2019Guru - Experienced User
Might do a search on doorbell. There are a few threads regarding this.
- KaiyuanbenJul 08, 2019AspirantYeah. Seems like I need to disable certain orbi functionality to get the doorbell work but no definite answer yet. It is case specific.
- FURRYe38Jul 08, 2019Guru - Experienced User
You can temporarily disable the 5Ghz SSID broadcast to see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Check out those other door bell threads. Hopefully you will find something that helps.
- KaiyuanbenJul 08, 2019AspirantYeah. Need to do more research.
