Uplink01
Dec 01, 2016Star
Questions/feedback about the Orbi, just moved from eero...
Hi, New Orbi customer here. I just setup my Orbi today, updated the firmware on both devices 1.4.x. That seemed to be a bit of a manual process, but looking at some other threads, it looks like th...
peteytesting
Dec 02, 2016Hero
hi
yes
1. i believe the app is coming
2. yes the orbi has both ap and band steering which assists in roaming between the router and sat but its not prefect as some client devices are whats called sticky and will struggle to let go of one transmission to move to the other but the steering helps with most devices
3. i think the sta/s just resync and dont reboot as such
4. yes it is lacking selection to the speed test servers , the whole speed test thing is quite new and its worth making a suggestion on how you would like it improved
5. you can access each sat/s gui by their ip address and see the attached list for the sat/s , from that you can work out whats then connected to the router
pete
