jerome-73
Dec 19, 2021Initiate
Réactivation Netgear Armor impossible (RBR350)
Bonjour, Suite à un changement d'opérateur, j'ai procédé à une réinitialisation de mon routeur. J'ai souscrit à Netgear Armor, mais je n'arrive pas via l'appli iOS Orbi à réactiver cette option....
Dec 19, 2021Guru - Experienced User
en anglais s'il vous plaît
Netgear has set up a community forum specifically for the Armor product. Most of the people who watch that forum are more likely to have experience with Armor and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
https://www.netgear.com/landings/armor
Good Luck.
jerome-73
FURRYe38 wrote:en anglais s'il vous plaît
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armorhttps://www.netgear.com/landings/armor
Good Luck.
Hi,
Thank you for your advice, which I will follow.
I apologize for my message in French. I had not paid attention to these particularities of the forum.
Good day to you,
- FURRYe38Dec 19, 2021Guru - Experienced User
:smileywink:
