ihateorbi
Aug 05, 2019Aspirant
R50 something
how you get it to stop giving you the incessant not found screen or asking me to login to every site i go to. this is some ridiculous cluster**bleep** of a product. (and one that has security added o...
ihateorbi
Aug 16, 2019Aspirant
I can return the 2nd batch to Costco, but I'm still stuck with the first batch. Then what? This stuff is supposed to be plug and play. The instructions say so. Plug it in and it works.
ekhalil
Aug 16, 2019Master
Please do the following test:
Please open a Command Prompt on any computer attached to Orbi and type:
> tracert 8.8.8.8 (or traceroute 8.8.8.8 if you're using a Mac computer) and post the results so we can help you further.
- ihateorbiAug 16, 2019Aspirant
Last login: Tue Aug 6 14:00:46 on console
(base) HQSML-1649490:~ krenne952$ traceroute 8.8.8.8
traceroute to 8.8.8.8 (8.8.8.8), 64 hops max, 52 byte packets
1 172.16.0.1 (172.16.0.1) 6.451 ms 4.074 ms 4.287 ms
2 10.0.0.1 (10.0.0.1) 10.554 ms 10.372 ms 6.333 ms
3 96.120.77.57 (96.120.77.57) 14.775 ms 18.392 ms 16.072 ms
4 68.85.193.237 (68.85.193.237) 17.113 ms 19.605 ms 15.283 ms
5 162.151.181.9 (162.151.181.9) 24.362 ms 19.723 ms 18.138 ms
6 be-201-ar03.ivyland.pa.panjde.comcast.net (96.108.181.21) 22.542 ms 19.000 ms 20.283 ms
7 69.241.64.98 (69.241.64.98) 23.519 ms 25.396 ms 21.297 ms
8 * * *
9 dns.google (8.8.8.8) 24.093 ms 22.305 ms 21.342 ms
Comcast was installed yesterday. I do not have a manual for the modem or know how to do anything to it.
- ekhalilAug 16, 2019Master
ihateorbi wrote:.....
Thank you for this.
The above shows very clearly that you have two routers in your network. Orbi has the IP address range 172.16.0.x and the Comcast has the 10.0.0.x which is causing you the issues you're seeing.
You have two options:
- Change Comcast to pass-through or DMZ mode.
- Change Orbi to AP Mode. You can change Orbi to AP Mode in the web GUI (orbilogin.com) under >> ADVANCED >> Advanced Setup >> Router / AP Mode
