NicaBen
Feb 05, 2021Follower
R8000-100NAS SSL certificate not trusted
No issues with my router or WiFi until this morning. When attempting to connect to my WiFi on my android phone I received a pop up, that reads, "SSL certificate not trusted" The security for this ne...
Feb 05, 2021Guru - Experienced User
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Good Luck.
NicaBen wrote:No issues with my router or WiFi until this morning. When attempting to connect to my WiFi on my android phone I received a pop up, that reads, "SSL certificate not trusted" The security for this network isi not from a trusted authority. We do not recommend that you connect to this network. I select connect anyway and it gives me another screen that reads: The request URL was not found on this server. https://myattwg.att.com.
- vajimFeb 05, 2021Master
FURRYe38 wrote:Please post about this here for your model router:
Good Luck.
try this:
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
