Rayc80
Mar 02, 2022Follower
R8000p setup with 2 additional routers on ine network
This setup is in a church the R8000P connected in one room with a concrete wall between them, ORBI RB20, the other router is a R7000 in a seperate building but under the same roof. All are running ...
Mar 02, 2022Guru - Experienced User
Really not sure what you have going on.
1. bridge mode might not be what you think? Basically it turns the router into a wireless bridge to connect back to a different router. Maybe you mean you're going to leave the r8000 in router mode and the other devices in access point mode?
2. are you having issues or just seeing if your setup is feasible?
