Hoodleehoo
Feb 06, 2024Aspirant
Radically different speed tests on our two phones from wifi (RBS10)
My wife's iphone 13 is getting 300-500 mbs from the wifi no matter what app or speed test we use. My Galaxy A54 is getting 5-40 mbs on the same wifi using the exact same tests. What the heck is going ...
Hoodleehoo
Feb 08, 2024Aspirant
Similar problem with att air but not nearly as big of a difference. I just used the model number of the satellite because I couldn't find the model number of the router itself.
CrimpOn
Feb 08, 2024Guru - Experienced User
Does the Orbi app Device Manager or the web interface Attached Devices show both phones connected to the same Orbi unit (router or satellite?)
I believe the A54 "Settings" will display the "Link Rate" of the WiFi connection. What does it show?
