PeterAlex
Apr 10, 2020Follower
Raident Heating
Hello, I have a narrow 3 story house with raident heating on all floors. How well does Orbi penetrate these infloor system. If your not familiar with raident heating, it's plastic tubing run in the f...
tucsontico
Apr 10, 2020Virtuoso
Your issue with radiant heating in the floor is very common. The problem is not the tubing but the foil used to reflect heat into the room. Any metallic object will disrupt all RF energy in some way. The higher the RF frequency (e.g.,5 gHz) the more it is effected. The lower the frequency (e.g., 2.4 gHz) the less it is effected. Additionally, non-metallic building materials can cause similar absorption and reflection (e.g., concrete or metal wall studs). Almost any router will struggle to get good wireless signals in your type of home.
If you decide to try an ORBI, I recommend hard wiring the satellites to the router via ethernet cables. That way you can place the router on the main living floor and a satellite on each floor. This should give you the best coverage. Good luck!
