mad153
May 07, 2020Follower
random disconnects and slow downs
hello! I recently purchased my first orbi system: RBR50 and RBS50 satellite. My experience so far has not been good. My devices randomly get kicked off the network (a firmware update did help) and i...
May 07, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Has a factory reset and setup from scratch been performed since last update?
Modem Combo Units: https://community.netgear.com/t5/Cable-Modems-Routers/What-s-the-Difference-Between-a-Cable-Modem-and-Cable-Modem/m-p/1864698#M21950
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
