Gnowsone
Oct 16, 2019Follower
Random Ping Spikes
Recently, we have moved to an Orbi mesh wifi system, it works really great getting really good download and upload speeds. However, often when gaming the ping which is usually about 20-30 spikes to a...
Oct 17, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
