DJMartinSr's avatar
DJMartinSr
Random restarts
My Router randomly resets multiple times during the day. The router resets and flashes a with the white light then the one satellite flashes with the purple light. It takes about 8 minuted, then it comes back up. I've updated to the latest firmware v2.3.5.30 and set the channel from auto to 9... The unit is over a year old.. Any help would be greatly appreciated..
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. Channel 9 is not recommended.
    Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings.
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    • DJMartinSr's avatar
      DJMartinSr
      What is the Mfr and model# of the ISP modem the NG router is connected too? Arris Model#TM822G
      Is the Orbi system operating in Router or AP mode? - Router
      What is the size of your home? Sq Ft? 4,000 SqFt
      What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. Approximately 45 Ft
      Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. Channel 9 is not recommended. Was set to Auto now set to 1
      Any Wifi Neighbors near by? If so, how many? Yes, 2
      Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings. - Not enabled by default. Has been added
      Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). - Done Still having issue
      Has a factory reset and setup from scratch been performed since last FW update? Yes. This was performed,
      I wanted to point out nothing has changed since the original config. Problem started, then performed the upgrade. Factory reset, and reconfigure from default.
      Thanks
      • Retired_Member's avatar
        Retired_Member
        Thanks
        why did you upgrade your firmware?
