CrimpOn
Apr 24, 2020Guru - Experienced User
Random Trivia: Why does disabling Guest access also drop the primary SSID network?
I had enabled Guest access some time ago as a test and decided today to "clean house" and disable Guest access. Clicked "Apply" and the icon spun, and spun, and spun. For at least a full minute. I...
I believe the wifi section gets dropped and rebooted when Guest Network is enabled or disabled...
- tomschmidtApr 24, 2020Virtuoso
I have observed the same thing, any changes to the WiFi settings (power level, SSID broadcast, etc) appears to restart all client WiFi channels (maybe not the backhaul WiFi channel).
