jlowe1225
Aug 09, 2019Aspirant
Range of RBK23
Have Model RBK23 with 2 satellites. Trying to establish Ethernet connection from satellite to a receiver at a boat house about 200 ft away from my main router in home. I suspect the range is not suf...
- Aug 09, 2019
Rather than hardwiring any other suggestions for connecting Ethernet 200 feet. Once used a Channel Master device that worked
Aug 09, 2019Guru - Experienced User
Whats the distance between the RBR and RBS? 30feet or more is recommende. Seen upwards of 50-60 feet from other user posts. However 200 feet is just to far. You would be best served if you could get a CAT6 LAN cable either strung up or buried from the house to the boat house and install a dedicated AP there. I presume there is power at the boat house?
