Enllorvall
May 27, 2019Aspirant
Raspberry pi 3 can’t see Orbi Network
Hi. I have a Raspberry Pi model 3 with Libreelec SO on it. When I try to connect by wifi to the network generated by my Orbi system, I can’t see the network’s SSID on the raspberry. I can connect wit...
- May 27, 2019I think that the issue is that the Pi can only see the lower channels in the 2.4 GHz band.
In the Wireless Settings in Orbi please set the 2.4 GHz to channel 1 or 6 and see if the Pi will see it.
Enllorvall
Thanks, but didn’t work. I unchecked the “enable SSID broadcast” option under “advanced wireless settings” on the 5ghz, but nothing happened... My raspberry continues not seeing my Orbi Network (I rebooted the raspberry after the change).
I attach you my actual configuration of the Advanced wireless menu. It is correct?
thanks again
May 27, 2019Guru - Experienced User
After unchecking the SSID broadcast you did apply the change right?
How do you have the SSID name configured on the Orbi? I presume other devices see this SSID name?
Does the Pi see any SSID names at all? Try a simple SSID name on the Orbi to see if the Pi can pick up this simpler SSID name.
Enusre the Pi's WiFi drivers are up to date. Might ask the Mfr of Pi about any wifi issues with Orbi.
- ekhalilMay 27, 2019MasterI think that the issue is that the Pi can only see the lower channels in the 2.4 GHz band.
In the Wireless Settings in Orbi please set the 2.4 GHz to channel 1 or 6 and see if the Pi will see it.- CrimpOnMay 27, 2019Guru - Experienced User
Absolutely! The Orbi region is set to Europe, which allows channels above 11. There appears to be a "fix" for Raspberry to allow the higher channels: https://tosbourn.com/get-channels-12-and-13-on-the-raspberry-pi-3/
- EnllorvallMay 28, 2019Aspirant
Yes! Changing the channel finally worked and my raspberry saw the network. I didn't have time to apply the fix CrimpOn suggested, but I'll update the thread when i'll do it.
One final thing: if I uncheck the 5ghz broadcast, it means that my entire Orbi network it's going to work at 2'4 ghz speed, even with the devices that support 5ghz? If is like that, it's not worth the change, I prefer not connecting the raspberry but having more speed in the devices that support 5ghz.
Thanks everybody for your help, and sorry for my awful english!
Enrique
- CrimpOnMay 28, 2019Guru - Experienced User
Enllorvall wrote:One final thing: if I uncheck the 5ghz broadcast, it means that my entire Orbi network it's going to work at 2'4 ghz speed, even with the devices that support 5ghz? If is like that, it's not worth the change, I prefer not connecting the raspberry but having more speed in the devices that support 5ghz.
You are correct. Disabling the 5G broadcast is only a temporary solution to get certain devices to connect at 2.4G. Once those devices have been connected, the 5G broadcast is immediately enabled again so that "everybody is happy."
In the case of your older Raspberry Pi, disabling 5G was never a solution. The two possible solutions remain: (1) set the Orbi 2.4G channel to 1, 6, or 11 rather than leave it on "auto", or (2) change the Raspberry Pi network settings to "Europe" in the hopes that the Pi will then pick up the higher WiFi channels. (1) is easy, quick, and known to work. (2) turned up on a Google search and "might work."
