Enllorvall
May 27, 2019Aspirant
Raspberry pi 3 can’t see Orbi Network
Hi. I have a Raspberry Pi model 3 with Libreelec SO on it. When I try to connect by wifi to the network generated by my Orbi system, I can’t see the network’s SSID on the raspberry. I can connect wit...
- May 27, 2019I think that the issue is that the Pi can only see the lower channels in the 2.4 GHz band.
In the Wireless Settings in Orbi please set the 2.4 GHz to channel 1 or 6 and see if the Pi will see it.
May 28, 2019Guru - Experienced User
Thanks for letting us know the lower channels fixed it. Seems like the Pi3 needs a update to it's wifi adapter.
Enjoy. :smileywink:
