Arno_71's avatar
Arno_71
Raspberry PI 3 can't see RBK50
Hi,
I recently acquired the RBK50 and everything is working as expected for all my Apple and Android devices.
However, I also have 2 Media Centers based on Openelec / Libreelec on Raspberry PI3. Since I moved to Orbi, those 2 devices don't see my wireless network at all. I can still see my neighbours Wifi, but can't see mine. If I start my previous Wifi system, it is properly seen by the Raspberry PI3 (so it's not an issue with the PI).
Is this a known limitation?
Anyone having the same issue?
Thanks in advance,
  • Arno_71's avatar
    Arno_71
    Jun 11, 2017
    Thanks OrbiPhilip. Some update here. I performed some more tests and found out that when forcing the 2.4Ghz Channel instead of using "Automatic" - the Raspberry Pi were able to see the wireless SSID.
  • FWIW, my Pi3 running raspian sees my Orbi just fine. I just remoted in (VNC/GUI), changed the preferred router, and clicked Ok.  Never even missed a beat in my VNC session.  That said, mine is most likely connecting to my satellite (RBS50)
    • Arno_71's avatar
      Arno_71
