Musicfan145
Dec 26, 2021Aspirant
Raspberry Pi 3B won’t connect to Orbi Pro SXR80
I have three different Raspberry Pi Model 3B devices that I cannot get to connect to my Orbi Pro SXR80 Wi-Fi system. They all will connect perfectly with a wired connection. When I scan for SSIDs, the...
CrimpOn
Dec 26, 2021Guru - Experienced User
My Pi 3B connects to a residential Orbi (RBR50) with both ethernet and WiFi.
I followed the directions to create a WPA_supplicant file in this guide:
https://www.seeedstudio.com/blog/2021/01/25/three-methods-to-configure-raspberry-pi-wifi/
(My goal was to set up a "headless" Raspberry Pi, so it had to connect to WiFi when it booted the first time. I followed the directions to enable SSH and define the WiFi network. on the SD Card before inserting it into the Pi.
