Navellani1
Jun 25, 2024Follower
Rax50v2 i Cannot connect Google Home Cams
Google Nest Cams won't connect. Google doorbell cams connected no problem. Wyze cams also connected no problem. Lorex floodlight with cam also connected. I tried everything from resetting the netgear cable modem and nighthawk AX6 AX5400 router. I reset the camera and unblocked access on the router admim site. I even called my ISP, Optimum who confirmed the network wasn't blocking access and the router was visible to guests. I configured the guest network and confirmed it was also visible. This router is awesome and the 2 cameras previously worked fine with the Optimum cable box. I checked for firmware updates on all the previously mentioned devices. Finally, I put in a service request with Netgear support, and sadly will have to bother them because anything else is above my pay grade. Not a big fan of the Google Nest or home apps. If anyone has any suggestions I'd be grateful.
1 Reply
what modem is it from netgear?
Is ipv6 enabled?
is access control enabled or disabled?
