ChuckinJapan
Oct 26, 2018Star
RB 50 iPhone App
I cannot sign in to the iPhone Orbi app to control my based station and extension.
The sign in page shows "admin" on the User Name line and I cannot edit or change that to my saved user name. S...
- Oct 29, 2018
Did it work for you? Sometimes the update in iphone doesn't work so the app needs to be fully removed and re-installed again.
Oct 27, 2018Guru - Experienced User
Try removing the app from the phone, reboot the phone then re-install the app and try again?
ChuckinJapan
Oct 29, 2018Star
Thanks. That process reminded me of the steps necessary since I hadn't used the iPhone app in some months.
- FURRYe38Oct 29, 2018Guru - Experienced User
- ChuckinJapanOct 29, 2018Star
The deletion, iPhone restart and reload of the app did work. Thanks for the suggestion.
- FURRYe38Oct 30, 2018Guru - Experienced User
Enjoy. :smileywink:
