Yatesj's avatar
Yatesj
Follower
Mar 14, 2021
Rb10 I can not get my satellites to connect
  • michaelkenward's avatar
    michaelkenward
    You won't get much feedback with such a limited description of the problem, especially when you have posted in the wrong place.
    You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
    Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
    Orbi - NETGEAR Communities
    You'll have to tell people what you are doing and where it goes wrong before you can get any useful help.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    That page will also have any software, firmware and drivers for your device, if they exist.
    Look for the model number on the label on the device.
    Begin with the Quick Start/Installation Guide.
    You can help people to help you by providing the information suggested in this forum's header:
    Subject (Include model number and brief summary)
    Model (Recommended - Helps the community give the best answers)
    Body (Include additional detail including model version, firmware, OS and environment where relevant.)
    They are there for a good reason.
