ballintex
Mar 25, 2021Aspirant
RB20 drops connection after update v2.6.2.104
Router RBR20 RBR20 V2.6.2.104 No new firmware version available. Satellite RBS20 Orbi Satellite-1 V2.6.2.104 No new firmware version available. I updated like most and still no r...
CrimpOn
Mar 25, 2021Guru - Experienced User
Can't hurt to turn off automatic Daylight Saving Time adjustment. (Who cares what time the Orbi thinks it is?)
If that doesn't work, time to "go back" to a previous firmware.
- ballintexMar 25, 2021Aspirant
Turn off the daylight savings adjusted. Even though it was enabled, the time was still reflecting predaylight, so behind and hour. We will see if that works, I tried reverting back the firm ware update, the router worked but the satelight still had the new version. And it still crashed multiple times. So heres to hoping the timezome trick works..
- chrisgoodson1Apr 14, 2021Aspirant
Did turning off Daylight Savings help? And if so, where do you even do that? Can't find that setting anywhere.
- ballintexApr 14, 2021AspirantI did turn it off and it worked. It must create issue between the timestamps and my ISP DNS servers. Log into router, then Advanced Tab->Administration->NTP settings there you will check box
Automatically adjust for daylight savings time, make sure its Unchecked.
