ballintex
Mar 25, 2021Aspirant
RB20 drops connection after update v2.6.2.104
Router RBR20 RBR20 V2.6.2.104 No new firmware version available. Satellite RBS20 Orbi Satellite-1 V2.6.2.104 No new firmware version available. I updated like most and still no r...
ballintex
Turn off the daylight savings adjusted. Even though it was enabled, the time was still reflecting predaylight, so behind and hour. We will see if that works, I tried reverting back the firm ware update, the router worked but the satelight still had the new version. And it still crashed multiple times. So heres to hoping the timezome trick works..
chrisgoodson1
Apr 14, 2021Aspirant
Did turning off Daylight Savings help? And if so, where do you even do that? Can't find that setting anywhere.
- ballintexApr 14, 2021AspirantI did turn it off and it worked. It must create issue between the timestamps and my ISP DNS servers. Log into router, then Advanced Tab->Administration->NTP settings there you will check box
Automatically adjust for daylight savings time, make sure its Unchecked.- chrisgoodson1Apr 14, 2021Aspirant
Thanks. Unfortunately, mine was already unchecked. So, I guess that's not my fix. And I was hopeful. Crap.
- FURRYe38Apr 14, 2021Guru - Experienced User
Factory reset the RBR and setup from scratch. Be sure to not enabled Traffic Meter during setup. DST can be enabled if your in the USA region.
NG already acknowledged that the problem was with Traffic Meter:
chrisgoodson1 wrote:Thanks. Unfortunately, mine was already unchecked. So, I guess that's not my fix. And I was hopeful. Crap.
