ballintex
Mar 25, 2021Aspirant
RB20 drops connection after update v2.6.2.104
Router RBR20 RBR20 V2.6.2.104 No new firmware version available. Satellite RBS20 Orbi Satellite-1 V2.6.2.104 No new firmware version available. I updated like most and still no r...
vajim
Apr 15, 2021Master
Ha_Ku_Na wrote:
vajim wrote:
FURRYe38 wrote:Factory reset the RBR and setup from scratch.
Netgear states factory reset should be used for lost passwords
To be precise
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
A factory reset deletes all personalized settings including your user name, password, WiFi network name (SSID), and security settings. A factory reset is necessary when you cannot recover your password.
of course....being precise is always good. Thanks for sharing.
Ha_Ku_Na
Apr 15, 2021Luminary
vajim wrote:
To be precise
A factory reset deletes all personalized settings including your user name, password, WiFi network name (SSID), and security settings. A factory reset is necessary when you cannot recover your password.of course....being precise is always good. Thanks for sharing.
No problem, I can share more if required ...
