bfish2534
Jul 01, 2020Follower
RB20 Speed Test
I have and RBR20 and one RBS20 satellite. We have been having a ton of issues with our speed slowing way down throughout the day (video's lagging, web pages slow to load, wifi calls dropping, etc). ...
Jul 01, 2020Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
