Alan22
Dec 24, 2019Aspirant
RB40 - can't update to latest firmware
Received an email from Netgear to update firmware for my RB40 to v2.3.5.34. My current firmware is V2.2.5.30. I followed the instructions exactly as indicated in the email. I am getting a message ...
CrimpOn
Dec 24, 2019Guru - Experienced User
There is a huge disconnect between the part of Negear that sends out those emails (I NEVER get one) and the engiineers who configure the firmware system. If the Orbi says, "No new firmware", then you are good. UNLESS you are experiencing a definite problem and are seeking new firware as a solution. In your case, I would delete the email and get on with life.
Alan22
Thanks. My current firmware is actually V2.3.5.50 (had a typo in my original post).
Nevertheless, I'll do as suggested.
- CrimpOnDec 24, 2019Guru - Experienced UserThat is the firmware I am sticking with until reports on the user forum convince me that an update is a good idea.
- michaelkenwardDec 27, 2019Guru - Experienced User
That "typo" kind of explains it. The exact numbers are important.
That v2.3.5.34 is older than your current V2.3.5.50.
