comrade
Aug 27, 2019Aspirant
RB50 - Nas over Wirless Backhaul
Hey Folks,
I have an RBR50 connected next to a Virgin Media modem, a RBS50 Upstairs thats connected Wired into my PC with a 1GB lan port. Now when I transfer from my hard drive on my PC to my NAS (nas is connected ethernet to the RBR50 Downstairs, I get about 45-50Mb/s transfer rate for a large media file. Over a wired backhaul (trapsed a 30m Cat6 cable downstairs) and via direct connection to the RBR50, I max out the Lan at 115Mb/s.
Now I know its 1st world problems but it seems that the wireless backhaul is reducing speed with maybe the encryption or the fact its wireless. The connection betweeen the 2 is good (1300M). Any options here or I am going to have to have a conversation with the misses about routing a cable across the bricks outside? Reason I ask is also I am due to get upgraded to the 500mb service from Virgin and with this being the main PC, I want it to be the fastest
Cheers
What is the model# of the ISP modem the NG router is connected too? Built in router here by chance?Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/19863/Ping-Test-to-determine-Optimal-MTU-Size-on-Router- comradeAspirant
~The netgear unit is in modem only mode, connected to the internet port of the RBR50 downstairs. Latest firmware on the Orbi for both the sat and router
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
