finnabbie
Jul 01, 2020Aspirant
RB50 & Ethernet Switch Issue?
I have an Orbi RB50 hardwired to my Xfinity modem via an ethernet switch with one wirelessly connected Orbi satellite. I have had an intermittent issue for years where wifi network wlll stop working ...
finnabbie
Current router firmware version is 2.3.5.30. I'm not sure if this automatically updates, but I can check for updates if that is advised?
The modern is a Cisco DPC3941T (Xfinity XB3)
Orbe system is operating in Router mode
I have previously tested the setup without the switch and it seems to work fine. Again though, the problem only occurs intermittently and sometimes infrequently.
Jul 01, 2020Guru - Experienced User
Well your ISP modem is a modem and router.
Is the modem bridged or in router mode? Bridge is recommended...
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- finnabbieJul 01, 2020Aspirant
Thanks.
The Xfinity router is currently in Router mode. When I first set the system up, I tried it in Bridge mode and my setup didn't work at all. I forget what the specific issues were but I can test it again. I will also try some of the other approaches and report back on how it goes.
- FURRYe38Jul 01, 2020Guru - Experienced User
Try bridge mode on the modem again. Be sure to apply the setting and let the modem reboot. You may want to power OFF both modem and RBR for 30 seconds, then back on with the modem then the RBR. The RBR should connect.
